RE: antenna
With 2.4, there is no need for an external antenna. The reciever wires should be spread out in two directions inside the hull, but honestly, I have never encountered a problem, no matter how I have them in the tank. It probably makes a difference if you are using a long range, like in aircraft, but for tanks, I see no difference.
