RE: 26cc Gas Engine
In the top post, it appeared that the engine was an off the shelf item.
I am aware of the changes methanol can give.
If you're into methanol and you don't mind the cost, and you want some power with broader (less touchy) needle settings,
then lower the compression, add 50% nitro and really blow the cobwebs out of the top of the bore.
