RE: downline braking
As I understand in pattern you want the plane to keep the same speed thru maneuvers.
On your vertical Down Lines (diving towards the ground) you do not want the plane to speed up and this is where the Braking effect of the prop comes into play. Either at idle or part throttle.
I could be totally wrong but am sure other will chime in.
