RCU Forums - View Single Post - DA Ignition Module
Old 10-16-2012 | 01:58 AM
Tony Hallo
Default RE: DA Ignition Module
ORIGINAL: aerobear
ORIGINAL: Ernie Misner
Are the DA modules made in the USA, how much $, and are they a viable option for replacing the ignitions on Chinese engines?
Ernie Misner
DA ignition is made in Australia. If my DA ignition dies it will be replaced by RCexl. You don't hear about DA problems
much, most likely because the owners just send it in rather than try and figure out what's wrong. Not that there's
anything wrong with that, just a different business model.
I friend's died. Symptons were several dead sticks and the engine became more difficult to start as failure progressed, this spanned two seasons. New module solved problem,
