RCU Forums - View Single Post - My Jagdtiger build.
Old 10-16-2012 | 10:59 AM
MAUS45's Avatar
MAUS45
Default RE: My Jagdtiger build.
Great build. I have a spare Tiger II lower hull I would like to turn into a JagdTiger. Do you have any photos of the inside of the lower hull showing how you reinforced the added section you used to lengthen the lower hull? Did you lay a section of aluminum plate across the the section that was added and just tie them together with the counter sunk screws to the hull sides and bottom?
Rudy
