RE: New project boat
I've been able to get the motors mounted using the mounts that came with the boat. I had to however use a dremel to modify them a little so that motors fit into them straight. Mounted the servo in the middle back of the hull with a couple of pieces of aluminum angle that were bolted to a servo mount and then shoe gooed to the bottom of the hull. Also, mounted both 50A esc's by the motors on the inside wall of the hull. Next to work on the water pickups in the hull.
