RCU Forums - View Single Post - Side Project in progress
Old 10-17-2012 | 08:09 AM
heavyaslead's Avatar
heavyaslead
Default RE: Side Project in progress
The T-55 generally is good mechanically, and as you noted less than desirable modeling wise.
It makes a good runner with surprisingly good tracking on all surfaces including grass.
The inside can get cramped as the profile is lower than the Pershing making electronics and wires sticking up a problem compounded with the elevation that uses some of the inner hull for max elevation.
I conserved space by installing an i-pod speaker in the extra fuel drum so as not to have to have a speaker box inside, and I was still able to install a slip-ring for 360+ turret rotation.
