RCU Forums - View Single Post - When to Cover? Weight?
Old 10-17-2012 | 02:59 PM
eddieC's Avatar
eddieC
Default RE: When to Cover? Weight?
Fuel doesn't have much impact. The CG will shift slightly aft with fuel burn so, if the CG is good with an empty tank, it will be a bit nose-heavy (and thus safer) with a full tank. That plane is so forgiving, you'll never notice the change in handling from full to empty.
