RCU Forums - View Single Post - Help for external pulse line
Old 10-17-2012 | 04:08 PM
oddy
Default Help for external pulse line
Hello Everyone
Well after trying I couldnt find a way to modify diferent intake manifolds to match the intake port of a Toro engine and walbro carb pulse hole
So I will need to do an external pulse line and I need your help with the following questions
1.- Do I need to block with JB weld the original holes in the manifold
2.- Do I need to block the pulse hole in the walbro carb
3.- For the external pulse line I now I need to make a hole and install a nipple in the carb but can I do the other hole in the plastic manifold (Instead of doing it in the engine)
Thanks a lot for your help, I really need to be able to start flying this Toro engine and installing a bigger carb has really been a challenge as the pulse line in the toro is 45 degreees and all Walbro carbs have its pulse hole at 90.
Regards.
VĂ*ctor.
