RCU Forums - View Single Post - a 2nd plane for me
Old 10-17-2012 | 06:54 PM
opjose's Avatar
opjose
Default RE: a 2nd plane for me
ORIGINAL: brhinaz
thanks for the responses so far. sounds like the u-can-do and freenzy might be to lightly builts. thanks for that info. for those of you who have seen the sticks, who makes a better one
hanger 9 ultra stick 60 or great planes big stick 60 ? i would like to make either one of them into a tail dragger ? again all, thanks for the help
In the .60 size the H9 Stik has flaps while the GP Stik does not.
However IMHO the H9 Stik simply doesn't need them.
On my Giant GP Stik, I NEVER use the flaps as such and instead turned them into inboard ailerons.
You get the same effect on the GP .60 Stik as it has big "barn door" ailerons.
Of the two I favor the GP Stik in terms of ruggedness. The H9 Stik is a slightly more agile flyer when properly equipped as it is a bit lighter.
Since this will become your most used plane ( trust us it WILL be so! ) I'd say Stik with the GP Stik. It's easier to repair because of the rather solid colors used.
On my first .60 I pulled off the Iron Crosses with a bit of heat from a heat gun and replaced them with USAF "Meatballs".
Ugly Stiks can be pretty too... ( heh ).
