Hi Gompy
"You can't make spikes with this kind of transformer"
<span lang="en" class="short_text" id="result_box"><span class="hps">Yes.
</span></span><span lang="en" class="short_text" id="result_box"><span class="hps">The ignition</span> <span class="hps">signal</span> <span class="hps">all</span> <span class="hps">dirty.
</span></span><span lang="en" id="result_box"><span class="hps">Take precautions</span> <span class="hps">against it,</span> <span class="hps">and you'll</span> <span class="hps">have no problems</span><span>.
</span></span>
"The SCR can only shutdown if the Voltage is going true zero."
<span lang="en" class="short_text" id="result_box"><span class="hps atn">Do you think '</span><span>ZVS</span> <span class="hps atn">CDI "</span><span>SCR</span> <span class="hps">is not</span> <span class="hps">turned off</span><span>?</span></span>
