ORIGINAL: Silent-AV8R
On my 18MZ I have it set up to display the motor pack voltage. So a quick glance let's me know what the voltage is. I also have an alarm set to warn me of low voltage (under load). Pretty handy feature. One quick way to avoid the low pack situation is to simply check the pack before take off. I use one of the testers Hyperions sells (and everyone else copied). Just one more way to cross check.
http://www.rclipos.com/HP-EOSSENTRY.htm
Hi Silent_AV8R,
Is it possible with the 18MZ to have two different alarms for the motor battery?
One as you have and the other one if the motor battery is lower the 41V (for ensample) when you turn on the transmitter?
Best regards,
Isaac Najary
