ORIGINAL: nitrosportsandrunner
lunch box is a good canidate. cheap kit, and if you either gear the stock motor lower or install a slighty better motor it pops wheelies with ease.
As mentioned above, anything with a brushless system and a good battery(2s lipo is best) will wheely.
The wheely king can wheely, but stock you usually have to reverse and then peg the throttle to get it off the ground.
ehh? mine wheelied just fine just hitting the throttle till I threw on a 3rd axle.
if it don't wheelie just put a lil weight at the back
