RE: Another Eindecker build
I did not quite finish the left wing tonight. Just need to finish up the wing tip. There is some shaping and sanding to do there. I've read where some builders thought that this would make a decent first kit. I'm not sure that I agree. While it is certainly not a difficult build, there seems to be some small omissions from the instructions. Glue this, remove that... If you've built a few kits, you know these thing will have to be done. Otherwise, I'm really liking the kit. It's almost impossible to srew up the wing construction, except as mentioned earlier.
