RE: New Pitts python radio setup help needed
A match box usually is used for multiple servos on a single control surface...like 2 or 3 servos on a single aileron. It allow you to set the servos so they don't fight each other at deflection. In this case I can see where the match box inside the fuse then hook each aileron servo to it would be easy
