RCU Forums - View Single Post - Evolution .45 alpha trainer engine runs backwards
Old 09-10-2003 | 04:51 PM
The_Matrix
Default RE: Evolution .45 alpha trainer engine runs backwards
You could also use an electric starter to keep from having the back compression stroke. Just a thought. On another note, are you sure engine is running backwards, and that the prop isn't on backwards instead? I have an evolution trainer system on my Extra Easy 2, with the 3 blade prop. Make sure the "E" on the prop is facing outward, you would be surprised how easy it is to make that mistake.
