RCU Forums - View Single Post - Propeller Installation Question
Old 10-19-2012 | 04:51 PM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: Propeller Installation Question
You should have the spinner backplate, then the prop, then a 1mm to 1.5mm thick thrust washer, then the prop nut.
If you have all that then unless you're using a very thin electric prop, you should be able to get it tight.
