Leopard2a6 no worky w/ DX6i
Isuccessfully bound my DX6i to the AR6000 receiver. Light is solid.
When Itried to set the range of the sticks per instructions "Push Set button for 1 second" the LED light flashes as suggested, but when the next step says to move the sticks the LED simply remains solid through all the sticks adjustments. The LED is suppose to blink in a pattern as written in the instructions each time I move a stick through it's range, but the LED is not indicating that it's accepting the input.
The lights on the tank work. The HVU light is on and making a low electrical noise.
I have the DMD "Throttle" channel connected to "Throttle" on the receiver. DMD "Steering" connected to "Aileron"
DMD "Gun" connected to "Elevator" and DMD "Turret" connected to "Rudder".
None of the channels are working.
Is the DMD control unit defective or is something messed with w/ my transmitter?
Update: Figured it out. Ihad the connectors in the RX backwards. They had tabs and only installed one way-until Isnipped the tabs off and reversed them.
Now Ineed to get it to fire.
