RCU Forums - View Single Post - My new build
Thread: My new build
Old 10-21-2012 | 11:36 AM
Gray Beard
My Feedback: (-1)
Default RE: My new build
Thinking I could get away with using CA and get moving a bit faster I tried to glue in the cross bracing. It's under a light load and I ended up with little pieces of wood blowing all over the shop. I ended up having to epoxy one side and wait for it to set up before I can epoxy the other side. Balsa is so much easier to work with! I may set the fuse aside and while it is setting up start building the wing?
