RE: Sharp turn just before leaving ground
It 's probably asscociated with torque. But it could be landing gear woes. Accelerate smoothly and use appropriate rudder inputs. Trick is you must anticipate when to use the rudder. Trying to compensate with the rudder after the plane is off course will have you zigging when you should have zagged. Takes a little practice.
