RE: Sharp turn just before leaving ground
Sounds like your tire is to tight on the right side. Is this as the tail comes off the ground? If it's just suddenly veering to the right, it won't be from torque, especially with a .25 up front.
Carefully check the rudder/vertical stab alignment, and the right thrust of the engine. (should be about 3 degrees.)
Jetts
