RCU Forums - View Single Post - NEW TO ELEC PATTERN ,INFO NEEDED
Old 10-23-2012 | 04:56 PM
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: NEW TO ELEC PATTERN ,INFO NEEDED
It really seems to be that easy. I have found the biggest problems I've had with lipo batteries is either leaving them fully charged, or not flying a few 'warm up' packs - you really should cycle them 5 times or so before using a lot of power.
The modern, quality chargers really take care of a lot of issues. They balance the packs, tell you when things aren't right, and are pretty easy to use.
When charging: you will likely charge two packs in series. You MUST have the battery that is plugged into the NEG lead also be on the NEG balance port.
