You may have the diaphragms and gaskets in the wrong position. On the side with the four screws, the gasket goes on the carb body side. On the side with the single screw, the gasket should be on the cover side. Check out the exploded view for your carb. Dan.
http://wem.walbro.com/walbro/group2.asp?FamilyName=WT
