RE: Need to switch channel, will any work??
Before you get too hot to change channels you may want to investigate the cause of the interferance. Your user manual should give you adive on how to test your range. Test it at home and at the field, just to make sure. If it glitches in both places you probably need to redo your antenna routing and test your connections. Make sure your RX battery is fully charged.
