RCU Forums - View Single Post - Elevator and Stabilizer Spacing?
Old 10-26-2012 | 05:04 PM
jester_s1
Moderator
Default RE: Elevator and Stabilizer Spacing?
Hinge gaps are a factor in the aerodynamic performance of a control surface, so it's good to specify a minimum spec and to seal them if needed. The biggest thing that sealing the gaps does is improve the control authority at slow speeds with big throws ie, when the pressure differential is the greatest.
