RCU Forums - View Single Post - 3 in 1 controller esky cp3 problem
Old 10-26-2012 | 08:33 PM
pshiv
Default RE: 3 in 1 controller esky cp3 problem
Additional Question:
After playing around with my helicopter a little bit Inoticed that when I put the throttle all the way up the green light on the 3 in 1 controller stays green like its supposed to. If I reverse the throttle switch on the remote, when the throttle stick is all the way down it turns and stays green. Has anyone else seen this before? I'm a little nervous to plug in the main motor to see what will happen if I start with the throttle all the way up. Also, do the two switches underneath the batteries might have anything to do with my problems? There's nothing in the manual about them.
Thanks in advance,
Parker
