RE: Elevator and Stabilizer Spacing?
Hi!
The gap should be kept at a minimum. An ordinary Model Magzine paper thick. That's easily done if you know what you are doing.
For a trainer it does not care as long as you keep the elevator/aileron stiff. Stiffnes is the most important thing to have in the elevator or aileron set-up.
Flutter comes from a too floppy servo/linkage/surface system!
