RE: Removing Cooked on Varnish from an engine
The trick is not to let the crockpot heat up the antifreeze too much. I make sure it is set on the lowest temperature setting, which gets it fairly hot, but no boiling. I haven't had any graying of any of my engines. I have cleaned 9-10 engines this way so far without graying.
