RCU Forums - View Single Post - Smoke pump?
Thread: Smoke pump?
Old 10-29-2012 | 11:38 AM
av8tor1977's Avatar
av8tor1977
Default RE: Smoke pump?
It would be interesting to try smoke on that 65cc Four Mix of yours. A properly tuned two stroke runs from 1000 to 1200 degrees exhaust gas temperature, with most running slightly rich and having an EGT of 1000. The four stroke engines generally run 1300 to 1400 degrees. The hotter exhaust should make better smoke.
AV8TOR
