RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
1/5th is where I am going.
The plan is to prototype a glas/herex fuse with a foam core wing. If it flies satisfactory a second foam wing will also be sheeted with metal and a mold made.
The final plan is full composite. That will be quite a large project (especially financially) but I have done some quite impossible tings with composites in the past (my "meister" work was a 1:1 scale copy of an original VDM Prop Blade for museum 109's) and so I guess I am up to the job.
Rev
