RCU Forums - View Single Post - Removing Cooked on Varnish from an engine
Old 10-30-2012 | 10:03 AM
  #49
Ernie Misner's Avatar
Ernie Misner
Default RE: Removing Cooked on Varnish from an engine
For a very nice and quick clean up on mufflers simply use a wire wheel on your bench grinder. It doesn't scratch the aluminum, just clean it up nicely IF you use a soft wire wheel. They are right beside the hard wire wheel in the hardware stores..... soft or hard, your choice, same price. They can then be polished if desired.
