RE: DX8 telemetry RPM pickup for Gas engines - SOLVED!!
I could not get it to work... (But I didn't look to see if the light was blinking) but in re-reading the thread, I noticed that there was some setting that was set to inh. Previously I had the RPM sensor working off the normal crankcase sensor and I didn't change anything but the motor. Is it improtant to set the inh when using this set up. What I did was install a "Y" connector on the electonic ignition, and tap the yellow signal wire sending it to signal on the TM1000 and leaving the TM1000 red and black off ( I cut the old RPM input lead and just used the yellow)
What am I missing. I did check the spark plug, and I am getting good spark when the magnet passes the pickup, so the signal should be there.
KKKKFL
