RCU Forums - View Single Post - getting epoxy in small areas
Old 10-31-2012 | 10:48 AM
CK1's Avatar
CK1
My Feedback: (60)
Default RE: getting epoxy in small areas
Put some vaseline on the hinge knuckle and work it into the joint,also put some vaseline around the opening for the hinge on both surfaces . This will prevent epoxy or glue from entering the hinge . I also use monoject syringes for getting the epoxy inside the hole for the hinge .
