RCU Forums - View Single Post - Vector flight 60 size Extra
Old 09-11-2003 | 07:38 AM
jcattera
Default RE: Vector flight 60 size Extra
I received my VF 66 Extra 300S a few weeks ago. I also am putting in a Saito FA-100. I think the Saito 100 should be enough powder to hang it. I thought of the YS 110, but too hard to get and pricy. Plus, the pressured tank could be and issue. I am almost finished with building it.
1. ) I would recommend using Robart Pin-Stlye Hinges instead of the CA hinges. I used 4 hinges in each aileron, 3 hinges in each elevator, and 3 in the rudder. I also sealed the topside of the hinge gap with hinge tape to avoid any potential flutter. I wrote a separate post on the hinge gap issue today. I had a 1/16" gap.
2.) To install the belly pan use four 4-40 brass inserts instead of the 4 tiny wood screws that are provided.
3.) I replaced the wheel axle with a Dubro 5/32" axle.
4.) Use plastic oversided washers for the two 1/4 -20 wing bolts, so it doesn't dent the wing when screwing them in.
5.) I am thinking of using 4-40 aileron rods instead.
6.) I fuel proofed the fuel compartment with fuel proof paint incase of a fuel tank leak.
7.) I am probably going to go with DuBro control horns.
8.) I beefed up the tail and stabilizer with 90 deg balsa stock in the inside corners. I plan on doing some high stress snap rolls.
Let me know how it goes!
