ORIGINAL: wfield0455
ORIGINAL: mhadjiky
Hello from Cyprus
I have received my Dragon last Friday.
Could you measure and tell me the length of your thrust pipe?
Many thanks
My thrust pipe is 22 3/8'' (57cm) long. Are you thinking that it's too short? Mine is a double walled pipe and doesn't have any sort of flare on the input end. I haven't studied it closely but when I was unpacking the Dragon I noticed a spun metal piece which I assumed was going to attach to the front of the pipe. I could be totally wrong about that though, as I said I've only gotten as far as unpacking it and have really figured things out yet..
I had order my Dragon directly from X-Treme Jets and today I received an email from John letting me know that I had received the wrong thrust pipe with my Dragon and that he will be sending me the correct one.
He also mentioned that the correct pipe length is 680mm..
Wayne
