Marc, my plan with this project (model) is to offer relatively big scale jet model in kit form, build from traditional material, for smaller turbine.
My goal is to made this Jet model not heavier than 12 -13 kg.
Knowing that, construction will be like on big warbird model, two piece wing with wing joiner. Modeler can choose will he made wing from one or two pieces. Wing will have pins in front an with two bolts on the rear trough which be fix on the fuselage.
That mean, wing will come from the bottom of the fuselage.
Advantage of that construction is that in wing hole, on the bottom of the fuselage, can be installed turbine, tanks, and other parts.
Front part of the fuselage will be removable, and that will be second area for installation heavier parts (batteries for example).
That will be only two holes on fuselage, and that will help to fuselage be strong, but simple for making...
More about this project you will find here:
http://www.rcuniverse.com/forum/m_10...mpage_2/tm.htm
Regards
Mirce
