RCU Forums - View Single Post - getting epoxy in small areas
Old 11-01-2012 | 02:04 PM
sweatybetty
Default RE: getting epoxy in small areas
ORIGINAL: acdii
See if you can find a syringe. I found a 3 pack at my LHS and they work great. I haven't used it for epoxy, just aliphatic, so it cleans up nice. I should be resistant to alcohol, but not acetone, so cleaning the epoxy out will be a pain.
local farm supply should have syringes fairly cheap. i use the ones with a 16ga needle, but file the pointed end down smooth first.
