RE: getting epoxy in small areas
Well ___no one mentioned my method.
I have no glue coming to the hinge at all.
I drill the hole right through. If it has to be a dead end like in all solid wood then I also drill a 1/16" dia hole at the bottom of the hinge hole.
The idea is to have an outlet for the glue.
I apply the glue into the hole like someone said with a small rod. I do not use toothpicks that breaks. I use a smal wire or a straightened paper clip and swirl the glue all around the inside of the drilled hole. I then apply glue on the stem of the hinge to about 1/8" away from the pin (axis) and remove all surplus on the hinge.
When inserting the hinge the surplus goes out the vent hole or the open end if drilled through.
Careful using oil ___oil has the affinity to spread rapidly and you may end up with a shaped glue around the saw tooths without adhesion.
If the wood expands a bit then the hinge can slip right out. Vaseline is better but may not penetrate well intothe hinge.
I figure a method without any lubricant and without any glue squeezing out at the hinge axis is preferable.
Zor
