RE: G-26 ZENOAH, FLAMES OUT
I don't have a solution; only to say I have G26 that behaves in the same manner, but it is intermittent. The engine is mounted out in the open on the nose of giant ugly stik. Sometimes adjusting the carb works and then again it does not help. At other times when the situation occurs, an engine restart will cure the problem for a few flights and then we go back to square one. Replaced the carb and it did not help. Go figure.[:@]
