RE: G-26 ZENOAH, FLAMES OUT
Heat........ You are running hot when it loads up. Same as above recommendations, open up the cowl and let some air move. You can have the best baffeling possible, but it does no good if the HOT air can not get out. With the wrap around pitts, you are just compounding the issue.
Cheers
Derrick
