RE: G-26 ZENOAH, FLAMES OUT
If you enlarge the exits and kick out exit ports on the cowl it will increase the airflow. The portion of the cowl that makes the angle out creates low pressure. You could make them with triangle stock. Also putting baffeling to direct the air toward the head is very beneficial.
