RE: Titebond glue
If you don't already know it, here is a little trick for titebond that I use on occasion. paint a layer on two opposing surfaces of wood (thin sections of wood) and let them dry. Then, using an iron (monocote iron works) on a high setting, iron the two surfaces together. They will bond from the heat. I use this fairly often to glue wing sheeting onto ribs and such. EXPERIMENT FIRST!
