RCU Forums - View Single Post - Seized Up Engine?
Old 11-04-2012 | 05:50 PM
Dads like rc too
Default RE: Seized Up Engine?
are you sure it's not flooded? Is this your first nitro engine? Remove the glow plug and fuel line off the carb, then turn it over. Gently pull the pull start. If it's flooded fuel will blow out of the cooling head, do this until it stops. Re-install the glowplug and fuel line, prime and start.
