RCU Forums - View Single Post - ESM 50cc Spitfire Assembly
Old 11-05-2012 | 07:28 AM
ForcesR
Default RE: ESM 50cc Spitfire Assembly
<p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-size: 9pt; font-family: Arial">It&rsquo;s been a while since I last posted, the assembly of the 50cc ESM Spitfire is almost complete.I changed my mind from installing a G62 and purchased the new DLE 55RA, anice engine and should fit very nicely within the cowl, especially havingrear exhaust.
I have run into a problem with installing the engine mount cylinder, its too large in diameter to fit into the fuselage; it&rsquo;s over sized by approximately 1/16", (2mm). I am sure there are other ESM aircraft owners that have run into a similar problem with the fiberglass engine mount cylinder. Before I start hacking away at the fuselage; I would like to hear what other ESM aircraft owners did to allow the cylinder to fit into the fuselage.<u1></u1></span><o></o></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-size: 9pt; font-family: Arial"><u1></u1></span><o></o></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-size: 9pt; font-family: Arial">This ESM Spitfire build has been a real pain in the backside; I had to fix problem after problem that should have been picked up by quality assurance before the Spitfire was released by the manufacturer. All other problems were fairly easy fixes, but this engine mount cylinder installation may become a nightmare to fix/fit <v:shapetype id="_x0000_t75" stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" oreferrelative="t" o:spt="75" coordsize="21600,21600"><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><vath o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></vath><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype><v:shape id="_x0000_i1025" alt="" type="#_x0000_t75" style="width: 24pt; height: 24pt"></v:shape><span style="mso-spacerun: yes"></span></span><o></o></p><u1></u1><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-size: 9pt; font-family: Arial"><u1></u1></span><o></o></p><span style="font-size: 9pt; font-family: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-CA; mso-fareast-language: EN-CA; mso-bidi-language: AR-SA">Roger</span>
