RCU Forums - View Single Post - Larger planes handle wind better.
Old 09-11-2003 | 12:15 PM
BMatthews's Avatar
BMatthews
Default RE: Larger planes handle wind better.
Lou, you pretty much said what I did but I will take exception to the higher wing loading.
A higher wing loading means a higher stall speed and that stall speed can catch you unawares in gusty situations or when dropping down through the very strong ground shear effects that come with stormy days.
A heavier airplane with a higher wing loading only masks the effects by making the response to gusts seem less but a heavier or higher loaded model also takes longer to react to throttle or control inputs.
