RE: CDI gr8flyer55
Nyemi, is your new fixed source code the same as the source code in jake's excel sheet so we can make new curves and copy & paste the 2 tables as we did before?
I just tested your new fixed source code with the Led & switches fixed and it works beautifully!!
Thanks again for fixing the software. I need to make a few new 2 stroke curves but it tested good on my engine with the stock curve in it. The LED is now nice and bright so we can use it for a timing light again. Tested both tables and kill switch and they work fine.
I will test your 4stroke curves by the weekend. So far, I think the "C" curve will be the best but still have to test on my 4 stroke engine, too cold right now with snow coming today.
I am drawing a schematic and parts list for the HV board we will be using. Similar to an RCexl HV board but a different size. Almost all the parts except for the transformer can be bought from either Mouser or Digikey and I'll provide the part numbers for the parts.
Working on getting the transformers factory made and should have an answer back in a few days. The factory is close to where I live. I want to get them to make 50 at a time until I get orders from the forum users for kits. I do have the bare HV boards available already, etched and drilled, ready for parts.
John
