I see no issue with that
PR. On some like that with an aileron plate I have used thin foam tape and just CA'ed both sides of the thin tape. That way it gives a very thin cushion of foam that allows you to cut out the servo with a blade if needed later. Also have simply Ca'ed with foam safe directly to the foam side.
John
