RCU Forums - View Single Post - Let's gasify a Vanquish
Old 11-08-2012 | 09:28 PM
  #54
MTK
Default RE: Let's gasify a Vanquish
Front and rear phenolic adjusters
Reshaped the gear legs as shown; right was the original shape and left is the reshaped leg. Shaved 1/3 the weight, down to 42 grams. The gear is very strong at 42 grams and overall shape and rear rake are attractive too, so I am making a new mold for these.
The original white pants an left are a bit on the heavy side at 26 grams each. The narrower pants on the right come out of my mold with hard points built in. Alignment is in the mold; weight is a tidy 14 grams ready for paint. Throw in the aluminum axles I've developed for the pant hard points and the weight savings really add up.....
BTW- don't you just hate wheel rattle after a few dozen flights? It seems no matter what you do, you just can't quiet the beasties. Well, I may have discovered a solution. Need a bunch more flights on the wheel set-up to make sure but it's looking good so far
ID:	1818722   Click image for larger version
ID:	1818723   Click image for larger version
