RCU Forums - View Single Post - Servo Pulse - Weatronics
Old 11-09-2012 | 04:08 AM
proline8000's Avatar
proline8000
My Feedback: (12)
Default RE: Servo Pulse - Weatronics
Harryc yes you are right I was in the middle of somthing at work and was not going to post but must have ( brain fart) . The only differance you may see if you use 18ms or 21ms is when you use servo reverse the servo center may move. This is the same thing as when you use different mfg's servos on your factory systems
