Also make sure your not using to much throws in your surfaces. My 90mm was set to 10mm up/down for the Elevator and 8mm up and 6mm down for the ailerons. I dont recommend flaps or crow. The plane doesnt need it. It has a huge wing and will lift all on its own if the correct CG is used. Dont use your fingers!! Use a proper balancer.
Get video this time
